Update any app container running in your system, including the containerized embedded system and framework built with Pantavisor Linux. With the Pantabox utilities, the update
command downloads the most recent version of the container as specified by the source URL and tag in the src.json
file.
Before you begin:
For example:
pantabox
to display the menu and then select update
The BSP or Board Support Packages are composed of the Linux Kernel, drivers and firmware. It also contain the Pantavisor binary that is responsible for orchestrating containers and managing updates. All of these components are updated on-demand with the update
command. To read more about how Pantavisor Linux is architected, see, “Pantavisor Architecture”
Pantavisor updates the containers, and then applies the updates to the firmware, kernel and drivers and then reboots the device. Pantavisor keeps all states and will always you can revert back to a previous revision if needed.
See Also:
Have any questions or comments? Please join our community forum at Pantavisor Community Forum.
